Ultrawide - Work / Productivity
27 Apr 2020
Hi,
I have two laptops, one for work and one for personal use (mainly studying).
My work laptop is a ThinkPad X1 Yoga with a built in graphics display Intel UHD Graphics 620 4GB
My personal laptop is a 2017 macbook pro.
I'm looking to get rid of my dual monitor set up and replace it with Ultrawide monitor, to be used for work and studying only, not for gaming.
Do you think the two laptops can support a 49" 5120 x 1440? I tried looking for hardware requirements but information is somewhat lacklustre. The models I was looking at either LG or Samsung:
https://www.displayspecifications.com/en/comparison/1c5d991c5
But as a minimum I'm after a 3840×1080 60hz. Would anyone kindly advise what best way forward with this is? Will the two laptops support 49" (can they be reduced to 3840x1080?) or should I reduce to 34"? I'm mainly after size over refresh rate / performance.
Thanks
