umm imstalled xfx 6870
17 Jun 2009
Cambs UK
Hello installed a xfx 6870 and games work god on it.. but the internet pages seems blurry :confused: how come? i have installed latest drivers..
What Monitor are you using
What drivers have you installed 10.10 10.11 etc
Did you have a previous Nvdia card on the same OS
Have you uninstalled current drivers and tried a different set
yes i unisstalled my olde ATI drivers and used the 10.11 drivers..i have wins 7 64bit and always used ATI cards in this newish build.
im using a hdmi cable is this wise? using a 23 HD phillips screen.
I had exactly the same issues with a good quality 1.3a/c HDMI cable from a Radeon 5970 and 1920x1080p HDTV. All the Catalyst driver sets made no difference with HDMI, text was fuzzy looking, had a slight blur. I now use a good quality DVI-D cable, same 5970 and HDTV and games are much sharper looking and no more blur effect on text.
I know this might sound "nooby" but go into the ati CCC and "restore default settings"... I know this fixed the pink tint that happened with the 10.10's, its worth a put :)
Had this identical prob, desktop fine, but blurry texts in windows mail. See if MLAA is enabled in the CCC and disable it as had been stated earlier
