ummm.. wth?
  • Thread starter Thread starter 4p
  • Start date Start date
4p
4p
20 Jun 2006
Capital of The North
When i manage to get task manager up it seems explorer.exe is taking up a SHED load of CPU usage. Could be the problem?
On second thought the only thing i installed today was XAC update. Xray Anti Cheat...
It needed to add a component to directx...
somethings been corrupted, whether its a gfx driver or a virus not sure
try booting into safe mode see if that fixes it, then you want to do a system restore to the point before you installed XAC, see if that fixes it
Shortly after i posted this the PC was fine..
I'mm convinced its the XAC because it changed my directx, bet its corrupt :(
The gcard is fine i think!
Yea i can boot into safe mode, normal mode, everything. It just randomly happened :/
