Un playable frames in RCT3 with 8800
Permabanned
9 Aug 2006
hi all,
got an 8800gts 320mb recently and im getting unplayable frames (20-30) in roller coaster tycoon 3 playing at 800x600 :eek: i am using the driver on the disc which are 97 somthing or other but i have tried the 158.19s and they are even worse whats going on?
AA+AF on in nvidia panel?
also 20-30 is far from inplayable, if you said 15 it's unplayable, but dont exgaggerate, just say it runs slow...
How is your ram usage when playign it, ram filled?
I mean you've got a top spec gfx, top spec cpu, but only 1 gb of ram :confused: , you migth need 2 gb, but i can't say as i can't renmber how rct3 is on system resources.
Is it only in rct3, or in all games poor perf, if in all games it might be your card being faulty or your pci-e slot running at 1x...
Massive Attack said:
hmm, not sure how much ram im using as i dont kow how to tell but my pagefile is around 800mb
Don't you just find that the only time it goes slowly is when you're laying a blueprint for a rollercoaster? The rest of the time I bet you're above 60fps?
