Unable to boot not getting POST either
13 Jan 2010
Ammanford
Hello,
I tried to boot my pc yesterday and got nothing.
I have opened the case and when i press the power button once the fans spin for less than a second then nothing.
I have tried a new power supply, and pulled all the ram gpu etc so its pretty much just the motherboard left and i am still getting nothing.
The motherboard lights up.
Any suggestions would be gratefully received but i am thinking possibly a motherboard /processor failure?
See if you know anyone with a motherboard which is compatible with your CPU who is willing to let you test it?
Failing that you could buy a new motherboard, test it and return it if it still doesn't work.
Tried the paper clip test?
Have you tried starting the PC by shorting the 2 pins where the power switch is plugged into on the motherboard header with a screwdriver? or swap the power button and reset button over on the motherboard header as it might be a faulty switch on the case itself.
Worth a try, otherwise sounds like a faulty mobo
