Heres my setup
My ISP is virgin media with cable modem.
The cable modem is plugged into a Netgear TA612V VOIP router's Wan port.
A Netgear WPN824 Router is plugged into the Switch of TA612V and is basically configured as a Access point with DHCP disabled on it (enabled on the TA612V)
The IP addresses of all connected item are in the 192.168.61.x range
The netgear access point is .11 and I am unable to connect to it by typing the address into the web browser??
I can connect to the main router fine but I am unable to access the Access point. Is it likely to be the firewall on the router messing it up?
BTW I don't desperately want to connect to it, If I wanted to I could reset it and connect to manually with cable. Theres nothing wrong with AP as im using it now.
sid
sid
