- 28 Apr 2006
hello i have been trying (without success) to find a program which will display the temperatures of the components of my PC, cpu, gpu, hard drive etc. I've tried speedfan, asus probe and systool but none of them detect my specs.
With Speedfan, when i click on the 'clock' tab my model of motherboard is not listed (it's an asus K8N8X-LA). The HP website refers to it as a 'Diablo'. Under the 'readings' tab i have the following:
Temp1:-128
Temp2:41
Temp3:-128
HD0:30
All the voltage ratings are blank except for -12v which is at -16.97v, -5v which is at -8.78v and vbat which is at 4.08v.
I'm not sure if i've given the information you might need. If there's anything else i can add, please let me know.
Not sure if this is important but when i close speedfan down (without altering it's settings) a loud fan starts up. If i go into speedfan again the 2nd temperature decreases.
p.s. the temp2 reading above is after speedfan has been closed once and the loud fan has come on.
Thanks for any help!
Dave
Temp1:-128
Temp2:41
Temp3:-128
HD0:30
Dave
