Unable to establish LDAPS connection
8 Jul 2004
London
Hullo everyone,
I've been trying to set up LDAPS over SSL on a AD Server with little luck. I am hoping someone with a bit of knowledge can lend a hand.
Here are the steps I have taken:
1. Followed the article here to create/import certificates: http://support.microsoft.com/default.aspx?scid=kb;en-us;321051
I used CACert.org to verify domain ownership + create a Server Authentication Certificate and installed as directed above.
2. Used Port Query to confirm the AD server is listening on port 636: http://technet.microsoft.com/en-gb/library/bb877965.aspx
Starting portqry.exe -n AD-SERVER -e 636 -p BOTH ...
Querying target system called:
AD-SERVER
Attempting to resolve name to IP address...
Name resolved to IP_ADDRESS
querying...
TCP port 636 (ldaps service): LISTENING
3. Used ldp.exe to confirm a member client/server can establish a ldap connection to the server on port 389 (default) with no SSL. If I enable SSL, the client/server is unable to establsh a connection as expected. I then switch the port to 636 (LDAPS) and I get as far as this:
ld = ldap_open("AD-SERVER", 636);
Error <0x51>: Fail to connect to AD-SERVER.
and with SSL checked:
ld = ldap_sslinit("AD-SERVER", 636, 1);
Error <0x0> = ldap_set_option(hLdap, LDAP_OPT_PROTOCOL_VERSION, LDAP_VERSION3);
Error <0x51> = ldap_connect(hLdap, NULL);
Server error: <empty>
I have checked event log for anything suspicious but there are no errors of any kind. I have disabled the servers firewall whilst testing but I am still unable to establish any connection via LDAPS
Anyone able to shed some light on this?
EDIT
I am able to establish a local LDAPS connection (Port 636 + SSL checked) by using ldp.exe on the AD-SERVER machine but not from any client/server domain member.
Certificate is issued from CACert.org and I have installed their Root CA in the AD-SERVER's trusted root certificates folder.
I have installed it on the client but it makes no difference, they cant make a connection.
Its not just best practice, its a requirement for anything involving certs :)
Also, if you havent set the certification policy to auto issue then you'll need to request a cert for the client from the CA manually
I meant using LDAP in general, inlcuding programming it's much faster and more efficient to use FQDNs. Though obviously some things require it to work.
Hi Guys,
Thanks for the replies. The certificate is using the FQDN of the server. I tried to make the connection with the FQDN and got the following output:
ld = ldap_sslinit("AD-SERVER.DOMAIN.NET", 636, 1);
Error <0x51>: Fail to connect to AD-SERVER.DOMAIN.NET.
The certificate policy is set to auto-issue if I remember correctly.
