Unable to format memory card
10 Jul 2010
I found a 64 GB Sandisk microSD card in an old mobile phone and it's not size for a spare. I wanted to test the memory card, so used the "clean all" command in Diskpart. A while later it finished, so I tried to create a new partition, but it said something along the lines of being unable to allocate the free space.
After a very quick Google, I tried SD Memory Card Formatter from sdcard.org. This couldn't format the drive either.
Has Diskpart nuked the drive completely? Are there any other tools I could try?
Tried a different SD card reader?
If so then I'd say it's toast, although I likely to be diskpart's fault, just an unlucky coincidence
Just tried another card reader now and this is what I get from Diskpart:
DISKPART> select disk 5
Disk 5 is now the selected disk.
DISKPART> clean
DiskPart succeeded in cleaning the disk.
DISKPART> create partition primary
No usable free extent could be found. It may be that there is insufficient
free space to create a partition at the specified size and offset. Specify
different size and offset values or don't specify either to create the
maximum sized partition. It may be that the disk is partitioned using the MBR disk
partitioning format and the disk contains either 4 primary partitions, (no
more partitions may be created), or 3 primary partitions and one extended
partition, (only logical drives may be created).
SD Card Formatter just gives the message "Formatting failed" on both quick and overwrite formats.
I've always had good luck using Gparted on difficult drives / cards. Although that does requires either creating a boot disk or a Linux live CD
I've tried the command line and GUI version of Gparted, but I haven't had any luck with either. The card is toast, but it's not a big deal as it was going to be a spare anyway - so in the paper shredder it goes.
Yeah on that basis then it's dead. I've only had a few die, but at least Gparted gives you a decent error so you've got an idea of what's going on
I was beginning to think that lightning struck me twice last night. I was using a nearly brand new USB drive to test Linux distros on my netbook and at one point in between putting ISO images onto the stick, it suddenly just refused to accept any more writes from Windows. I even tried a another Windows machine to format the disk, but nothing would make the drive usable. It was only GParted, from a PartedMagic USB stick I had laying around, that made the USB drive usable once more.
