Unable to mount images
11 Aug 2004
Hi there,
For some strange reason I can't mount any images. I've tried different formats (iso, bin/cue, img etc) but they all don't work. The image mounts but when I try to browse it just says Windows cannot read from the disk it might be corrupted. I tried using both Alcohol 120% and Deamon Tools but it happens on both.
Any ideas?
Yup, should have added :o
It did work a few days ago. Also I did disable some services through services.msc but I've disabled them before without any problems. I might look into that
hottiger said:
It did work a few days ago. Also I did disable some services through services.msc...
Tried re-enabling those services?
See if it works then?
(If it worked, then you changed something and it stopped working... Usually you revert the changes and see if they caused them...)
