Hi, I have the above, never used linux before and am struggling with a couple of things, first is I have a WD mycloud 4TB I can see the files and play them but when I try to copy just get you do not have permissions to create file in destination, destination is a 4tb HD I formatted ext4 (wanted to use NTFS but not a option for it in Gparted)
The main use will be a plex server which when I try to add folder from WD mycloud it doesn't find location path
One step at a time I guess
