Uncaught FSODs
Status
Not open for further replies.
25 Nov 2011
I recently bought a 7950 crossfire arrangement, it works until i play FarCry3 and some instances of Youtube.
1. Total freeze - can't access TaskManager. Have to use RESET buttton.
2. Total freeze - can't access TaskManager and my Keyboard/Mouse LED's turn off, but screen and sound remain stuck. Have to use RESET buttton.
3. Partial freeze - W7 remains intact, catches error and allows me to access TaskManager and/or press the now windowed game's CloseWindow button.
Problem was the following: At a seemingly random time, the computer would freeze in one of the three ways stated above. At first it was only 1 and 2. So cleaned my PC of all drivers and software for my GPU setup, Defragged, wiped clean space and ran a registry cleaner. Followed by a reinstall of everything removed. Tested FarCry3 and got multiple instances of type 3, until i used the HBAO setting and got either a 1 or a 2, set HDAO for a mix of crashes. It has returned to being either a 1 or a 2 again. So i have multiple questions that need answering, such as why does this happen in said ways and why do my peripherals die are the first two of many really.
Side notes: Temps seem normal, i log CoreTemp readings and no core surpassed 72C before crash. Crashes in other games which are very rare are always handled to the best of my memory. I have tested my CPU and Memory and they seem to be ok.
RAID 0 SSD x2 (14Gb empty)
Z77XGDA-UD5
I73770K 4.5GHZ
8GB DDR3 2.4GHZ
7950 x2XFIRE via HDMI cable (ASUS 900Mhz/1250Mhz/1094Mv and Saphire 830Mhz/1xxxMhz/08xxMv) ASUS is the primary with the HDMI output used and Saphire is the slave set to mimick ASUS. MSI Afterburner sets both cards to 1000/1450/1094Mv.
750Watt PSU Bronze80+
I will add information as of when i can to this post in this thread. Thanks.
Better of posting in GFX section as it sounds like its GFX related mate.Worse with games that pound 99% GPU usage like FC3?
You sure thier both stable and are not these MSI cards like the one i got that black screens and bsods as the voltage is incorrect for a pre overclock? Upping my volts cured everything in afterburner.
Status
