Undecided on which card to choose
11 Aug 2007
Hi
I have been thinking about buying a new GPU recently and was dead set on buying the GTX 260: http://www.overclockers.co.uk/showproduct.php?prodid=GX-151-LT&groupid=701&catid=56&subcat=927, but now I'm wondering whether it would be worth going for the 512MB 4870 instead: http://www.overclockers.co.uk/showproduct.php?prodid=GX-137-XF&groupid=701&catid=56&subcat=939
I was also looking at the much cheaper XFX 4850 512MB: http://www.overclockers.co.uk/showproduct.php?prodid=GX-127-XF&groupid=701&catid=56&subcat=938
I generally want something that is as future proof as possible, basically making sure I am able to play the PC games of the next year or so at as high settings as possible, so what would you recommend? The resolution I use for gaming is 1680 x 1050 (on a 19" LCD) btw.
Thanks for your help.
I used to have a 1680x1050 monitor and the older GTX 260 with 192sp - they went hand in hand. Played everything on that setup comfortably. I also had a 4870 512mb on that resolution and the 260 was a definate improvement!
i would go for the 4870, will blow every game away at decent fps, and slightly faster than the 260 :D
Factor in the 260's overclocking headroom and its quicker in 90% of games.
Why? are you not allowed to OC the ATI's? lol
Hah, pretty much. May get 25MHz OC on the core. Hence Rv790 aka 4890, redesigned RV770 to allow higher clock speeds :p It was the 4870's flaw vs the GT200 cards
GTX 260 on the other hand, stock clock 576MHz - most people are running 700MHz+ Had mine 27/7 stable on 720MHz core, and that was the older 65nm one. The one OP linked it the new 55nm model.
