Undeletable JPG
23 May 2006
Blythe
I downloaded an image a while back and now I want to delete it the problem is ..... I cant. when i press delete on the keyboard nothing happens when I right click there is hardly any options and delete isn't one of them can somebody help please?
thanks
Install it then right-click on the file you want removed and in the context menu should be an Unlocker feature. Click on that and you'll get a window appearing telling you what other program has "locked" that file and you can unlock them.
Or if you look at the Unlocker site again there is a graphical version of what I've just said.
collisster said:
I gave it a go and unlock or unlocker isn't in the menu it is when I click on different files tho
When you installed it did you check that the context menu option was ticked? If it wasn't then it won't install that function into Windows.
oo
lads I'm back
and I've fixed it heres what i did :
I copied all of the audio files in that folder into another one
deleted the whole folder and the pictues went with it
emptied the recycle bin
added that copied tracks back into itunes
made itunes show up duplicates and I started the long process of finding all of the "gone rotten" files and deleting them out of my library
I think its worked =D
I'm not absolutely sure but I think it only runs when you right-click on a file and choose the Unlocker option. It then closes I think when you've unlocked the file.
