Hello!
I'm planning an extension and scheduled to start work in March. Whilst doing this we're going to swap out our boiler for an Air Source Heat Pump (plus external insulation) and fit wet underfloor heating to the floor of the extension and the rooms we're extending out from. We've worked on our house top-down. From the loft, to a refurb of the first floor and now the ground floor.
Our house is quite old. The first floor is built with joists and the floor is timber (not chipboard). We had carpet laid on the first floor, with the underlay being a rubbery sort.
As part of the knocking through process the builders are going to have to redo the ceilings on the ground floor, and I noticed that there's a product to allow you to install underfloor heating from below (see picture). Utterly genius idea!
My question is - will this work? Will the heating make it through the ceiling timber and the underlay and carpet? Is it safe to do this (I worry about the underlay giving off fumes).
