Understanding homeplugs
3 Jun 2007
Essex
Hi all.
Looking at moving away from my external ethernet wires that i use for distributing internet around the home and was looking at home plaugs as an alternative.
But my understanding is a shallow so can anyone advise if this will work below.
Router --> Homeplug --> Front room Socket --> Homeplug --> switch --> Devices
| -> Dining room socket --> Homeplug --> Switch --> Devices
That would be a total of 3 homeplugs.. Does it work likes this or would each homeplug in the other rooms need a home plug connected to the router?
I might be wrong with this, but my understanding is you just need the router plugged into the first homeplug.
Should work if I'm looking at it right. All you need is one homeplug at the router, and another homeplug for any switches you have. So for your setup, only need three.
This is how you would set it up
Thank you sir... that looks exactly how i imagined it... would that also extend to putting home plugs upstairs?
My understanding if the homeplugs are on different electricity loops its still works but at reduced speeds?
I've got the router downstairs attached to a homeplug, 2 homeplugs on the first floor and 1 in the loft and they work fine.
200mbps homeplug and the software is showing the router connected at 172, loft pc at 192, and the other pc on first floor at 196mbps. It fluctuates but it's never dropped below 120 for the router and 160 for the loft and other pcs.
From what I've tested the homeplugs act like a switch, if I want to access a device on the homeplug not connected to the router it just routes the packets straight to it bypassing the router.
