Understanding power supplies
24 Dec 2010
Anglesey
Hi, just wondering how do you know that a certain wattage will be sufficient for your system? And is having a really high watt power supply a problem?
I will be having an i5 3570k with a 7950.
Over clocking will be to a minimum.
Is a 600W power supply ok?
And what is the lifespan of psu? Because i hear a lot that go bust.
What's more important is the quality of the PSU. A generic 800w from the shop down the road probably won't be anything close and may in fact be dangerous.
A quality 600w with an i5 and 7950 should be fine, but you may also want to consider buying something a bit more powerful in case you want Crossfire/more hard disks etc. etc. in the future.
Decent brand should be an absolute requirement for a decent gaming system.
For modern PCs you should only count the +12 V to rate your PSU. Total power output shouldn't be a concern to the normal user.
Look up the thermal design power (TDP) for the GPU and CPU. This will give you a basic idea. Overclocking can exceed the TDP.
Maybe add 50 W for the mobo/ram/fans, some very high end ones maybe more. 10 W for a standard HDD/optical, less for a SSD.
So as an example.
i5 3570k - 77 W, HD 7950 - 180 W, mobo/ram 50 W, 20 W for 7200 HDD and DVD/RW. Gives you 327 W.
I personally spec to max of 80% usage. So 408.75 W +12 V. so a good 450 W could cover it.
With heavy overclocking 500 W - 550 W should cover it safely.
