- 5 Jul 2007
Hi folks
I used to understand the old Intel systems re bus and ram speeds but are a little lost with x99. My current setup is below (gleamed from CPUz).
i7-5820k 3.3GHz, multiplier 12-34
Bus speed 99.94MHz
Northbridge 1199MHz
Dram frequency 1066MHz, CL15-15-15-36
SPD - 1066MHz 15-15-15-36 1.2v, 1200MHz 14-16-16-31 1.2v, 1333MHz 14-16-16-35 1.35v
My motherboard manual suggests that anything above DDR4 2133 is 'overclocking'. My current ram reports itself as 2133 yet the part number is 2400C14
Thoughts....
1...'2400' is 1200MHz doubled ('DDR') hence 2133 is 1066MHz ?
2...This is CL14 ram so why does the spd set CL15 at the slower 1066MHz ?
3...Do CL timings notably affect performance like they did on the old systems ?, is it worth forcing CL14 instead of the current CL15 ?.
4...To run this ram at 1333MHz (top spd setting) do I need to up the bus or northbridge frequency ?, yes I see a voltage jump too. What about reliability if I do ??. Performance is great but reliability is much more important to me. I guess there is no way of running faster ram without at least 'overclocking' the bus frequencies (as apposed to simply increasing multipliers to run say DDR4-3600/3866 sticks)
Regards
Bus speed 99.94MHz
Northbridge 1199MHz
Thoughts....
Regards
