Undervolt i9-10850/10900
7 Jul 2008
Newcastle upon Tyne
I have an Asus z490 rog strix mobo
i have heard that the voltages can be aggressive and been suggested to undervolt
the main reason is to keep temps down
how do i go about doing this please
whats a good value to start with
You need to find out what’s stable volt for your current setup. That means manually dialling volts and multiplier and go into windows and do some stress test and so on
once you got to a OC level and volt you are happy with you go back into that voltage and set offset to get to the desired volts.
