http://forums.overclockers.co.uk/showthread.php?t=18509458
If you copy the red text into your 'PP_PhmSoftPowerPlayTable' value, it will give you a voltage of 1125mV if that's of any use imginy.![]()
It is actually reducing the voltage though because although MSI AB would allow me to adjust the voltage it wasn't actually changing it.
Trixx was the only program that changed my voltage with a gigabyte 7950 and i confirmed the voltage did change in GPU-Z
