Hi,
I just got a 1660Ti for a secondary PC, sat in a Phantec's Evolv Shift.
Doesn't run too hot, but i want to make it a little cooler to reduce fan noise, hence, undervolting.
I'm trying to follow some guides that are posted on LTT or Reddit in regards to the process, but it makes no sense whatsoever.
Using MSI Afterburner, i can adjust the pretty little graph that shows, BUT most of the guides list dragging the line DOWN to adjust the voltage. The up/down axis is frequency however?
Am i missing something obvious here?
Thanks in advance!
Thanks in advance!
