- 1 May 2006
Well, I've just got myself a Corsair 520w PSU, which seems to have solved some problems I had been having with crossfire, but not only that, my whole system seems more stable.
So I decided to undervolt my Opteron 165 from 1.35v to 1.325v - Is this ok to do??
I did this because my idle temps seem to be kinda high, 35C on both cores at idle (coretemp), and I'm using AS5 and an Evo 33 cooler with 2 80mm in a Push/Pull config.
So far it seems to running stable at near 2.5ghz.
I'm just wondering if I could lower the v-core further to lower temps again, or will this damage the chip ??
![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
