Underwater Camera
7 Mar 2005
The Voice Of Football
Hi all- am off to Egypt on sunday and want to do some underwater photography. I have a canon a70 but can't find any underwater housing for it that won't break the bank. Plus I go on sunday!
So any pointers or brands of underwater throwaway cameras that you would recommend?
thanks in advance guys
The disposable ones won't suvive the depths you'll dive to - most seem good to only 3 - 6m.
We found a film-based, non-disposable camera waterproof to 20m or so for about £30, but it took a few working days to deliver so I don't reckon you'd get one before you left. Can't remember the name etc either :(
Time to go looking round the shops I think :)
Edit: failing that you can buy them here, I'm fairly sure of it.
Just got back from boots. Got two kodak underwater cameras for a tenner. They are good to 15m deep so fingers crossed. I will post the results on here when i get back :)
I think they are the ones we used when we went to egypt (at least they were kodak and W/P to 15m), they weren't too bad although you will find that below about 1-2m the pictures will be a bit dark due to the lack of light. :)
Those are not too shabby, they work waaaay past 15m, but the colour is terrible, everything is blue.. :)
good luck!
without a built in flash forget anything below 10m-14m or so
most of the best photos though will be at the shallows where the natural light is best and the coral and fishes strongest in colour.
i hired a camera in the red sea when i was there a few weeks ago (canon s1 and housing). it was very expensive but well worth it but if i knew i was going i would have bought my own before i went.
If you are using those Kodaks, you might want to get the pics back on a cd, after which you can use adobe photoshop's underwater colour correction filter which produces good results. Not as good as having a colour correction filter in your camera's housing whilst taking the pictures but nonetheless you will see good improvement. Here's an example on a safety stop. Not the greatest framing i know, but just to give you an idea:
1. WITHOUT CORRECTION:
2. WITH CORRECTION:
HTH
m
You can't expect miracles with colours in Egypt..... White Nile, Blue Nile, Red Sea.......
Well it's not exactly that, the water adsorbs (dunno the technical name for it) different frequencies of light, so the further you go down, the less colours you have, so unless you have a decent flash (not one of these crappy things you have on your normal af camera, but a big external flash) or a damn big torch, you're going to lose quite a bit of colour.
