Over a week my home desktop gradually fell apart. At first, it would reach the Windows desktop and then freeze after a few minutes. Then it would go blank after reaching the Windows splash screen (and the same would happen with safe boot, and with booting to last known good configuration). Now, it reaches the motherboard splash screen and then goes blank. The machine still has lights on and at least some degree of power, but hitting DEL or f8 during startup, or trying to boot from CD or floppy, now has no effect. (Keyboard still works in other machines.)
Specs:
Asus A8N SLI Deluxe
Athlon 64 FX 55
160 GB Seagate Barracuda
2x512MB Corsair DDR PC3200
480W Tagan PSU
2x XFX Nvidia 6800GT
Sony 16x DVD-ROM
Pioneer DVD+-RW
Windows XP Home
Norton Antivirus 2006
ZoneAlarm
Spybot, AdAware, SpywareGuard, SpywareBlaster
During the deterioration I managed some tests:
Removing one of the two memory sticks made no difference. I ran Memtest for half an hour until freezing, with no errors. I later ran Memtest86 from floppy, for six hours with no errors (with both sticks installed).
I ran CHKDSK on two days. The first replaced "bad clusters" in eight unimportant files; the second ran without any complaints. I also ran Seagate online diagnostics without errors ("no SMART thresholds exceeded" and "extended drive self-test completed without error").
I re-installed Windows at least twice.
I almost never got blue screens. But, twice, I got the message "kernel stack inpage error".
BUT I was never able to complete any anti-malware checks without freezing.
I can't get into the blessed thing now since it freezes so early on in the boot process, so it seems that all I can do is replace bits of hardware until it works again? I guess the first thing to try is replacing the hard drive -- if a new one works, the problem is either the old HDD or malware; and, if it doesn't, then at least I can rule out malware. Makes sense, or any other cunning plans come to mind? Any other tests I can run on such a crippled machine?
in need of some Christmas spirit ... yohoho and all that ...
Specs:
Asus A8N SLI Deluxe
Athlon 64 FX 55
480W Tagan PSU
Sony 16x DVD-ROM
Pioneer DVD+-RW
Windows XP Home
ZoneAlarm
Good suggestion about a CMOS reset though, forgot about that
