- 22 Jul 2012
- London
So I just moved my main build (in sig) over to a test bench with a MO-RA 1080.
First of all, I ran the cards in parallel (using tubing/fittings) which provided even temps within a degree of each other.
After a marathon session of bleeding the blocks by turning the bench every way possible, I found that while temps were even, they were a lot higher than they were when running in serial in my case with 360/240. They were also a fair bit higher than when I ran 3x290 in parallel (using a triple FC bridge) with the same 1080 rad.
So I then drained it, ran them in serial and spent a while making sure they were bled. There's still a small bubble, but whatever
Now I'm seeing the second card running at up to 10°C higher than the first, when on my old setup there was around 3-6°C difference.
Apart from a possibly unseen air pocket, what in blazes do you think is going on here?
