Unexplained speed drop - O2 Broadband
30 Nov 2005
London
Hi all,
Had a very strange speed drop, downloads and streaming have slowed considerably over the last week.
Despite the fact my sync speed has stayed the same. Have rebooted router, upgraded firmware, checked for viruses etc.
Here are my line stats:
Code:
 login: admin
Password:
BusyBox v1.00 (2011.12.09-06:01+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 1144 Kbps, Downstream rate = 7172 Kbps
Link Power State: L0
Mode:                   ADSL2+
Channel:                Fast
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):       6.2             6.3
Attn(dB):       46.5            19.1
Pwr(dBm):       19.0            12.3
Max(Kbps):      9029            1148
Rate (Kbps):    7172            1144
                        G.dmt framing
K:              104(0)          33
R:              16              0
S:              1               1
D:              64              1
                        ADSL2 framing
MSGc:           59              16
B:              103             32
M:              1               1
T:              2               3
R:              16              0
S:              0.4994          0.9887
L:              1922            267
D:              64              1
                        Counters
SF:             15040528                579874
SFErr:          407             266
RS:             1955268726              0
RSCorr:         193870          0
RSUnCorr:       10976           0
HEC:            333             163
OCD:            0               0
LCD:            0               0
Total Cells:    4129759045              2465264032
Data Cells:     78688404                1147474966
Drop Cells:     514
Bit Errors:     0               2031290
ES:             207             0
SES:            0               7270
UAS:            40              0
AS:             244160
INP:            2.13            0.00
PER:            16.23           16.31
delay:          7.99            0.24
OR:             32.03           10.78
Bitswap:        38196           165
Total time = 1 days 19 hours 45 min 15 sec
SF  = 15040528
CRC = 407
LOS = 0
LOF = 0
ES  = 207
Latest 1 day time = 19 hours 45 min 15 sec
SF  = 4380786
CRC = 133
LOS = 0
LOF = 0
ES  = 62
Latest 15 minutes time = 15 sec
SF  = 927
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 15 minutes time = 15 min 0 sec
SF  = 55423
CRC = 1
LOS = 0
LOF = 0
ES  = 1
Previous 1 day time = 24 hours 0 sec
SF  = 5322365
CRC = 192
LOS = 0
LOF = 0
ES  = 96
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF  = 55485
CRC = 0
LOS = 0
LOF = 0
ES  = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF  = 55423
CRC = 2
LOS = 0
LOF = 0
ES  = 1
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF  = 55424
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Showtime Drop Reason:   8000
Last Retrain Reason:    8000
Code:
System Up Time 67:53:37
Port	Status	TxPkts	RxPkts	Collisions	Tx B/s	Rx B/s	Up Time
WAN	DHCP Client	2201288	3302014	0	599864	7134290	00:08:30
LAN	10M/100M	1115323	336549	0	2261	295	67:53:33
WLAN	11M/54M/300M	2414943	1616179	0	8025	1537	67:53:12
ADSL Link	Downstream	Upstream
Connection Speed	7172 kbps	1144 kbps
Line Attenuation	46.5 db	19.1 db
Noise Margin	6.2 db	6.3 db
Any ideas what could be wrong?
I've not at home using the internet but I'm getting some similar problem. I'm getting slow speeds. Wonder if anyone if there are a bit of noise on the o2 forums?
