Uni Fans AL, L connect 2 software and EKWB products.
13 Aug 2021
England
I'm changing my fans to some new Uni AL's, just waiting for the 3 pack and controller to comeback into stock.
I will have 7 fans in total and hope to use the L connect 2 software to control them.
Question is, how do I go about controlling my other RGB stuff and a water pump so it all syncs with the fans and L connect software?
I have the 011D XL case and then the EKWB, cpu block, GPU block and the EK side distribution plate which all have RGB and then the pump with the DP.
At the moment I use Armoury crate for any rgb stuff and AI suite for fan and pump control.
Can the DP, water blocks and the pump be connected to the UNI controller? I know the case rgb strip can but that isnt really important
I have the X570 f MB.
