- 11 Jan 2012
- Bedfordshire
Hi all!
Right, so my brothers PC keeps coming up with "Unidentified network", refuses to ping the router or out to the internet at all. He uses Powerline Adapters as his main form of connecting to the router.
I've tried all of the following but all result in the same problem (Not necessarily in order of what was done first)!:
The only PC that this is happening with is my brothers PC, all others PCs in the house work fine. The PC is able to connect to the internet when using a USB wireless adapter, however as you can imagine it isn't the ideal solution...
Anyone got any ideas at all?
This has been baffling me for AGES now and I think its time to ask around!
Thanks in advance!
- Assigning a static IP on the network card
- Binding IP to MAC on the router
- Purchasing a new NIC
- Plugging directly into the router and removing the Powerline Adapters from the equation
- Reinstalling Windows
- Purchasing a new motherboard/CPU
- Changing all cables
- Changing the router
Thanks in advance!
