- 1 Mar 2013
Okay so first of all on my old mobo, i would connect and be able to share my internet connection over ethernet to any connected device (xbox etc) just fine.. When i installed my new motherboard (P8H61-MX USB3 ASUS) i would be faced with "identifying..." then "unidentified network" status on my onboard ethernet, trying every fix i could find, manual configuration, different cables, different drivers and different devices to connect to i would still get the same error, it would not maintain any kind of IPV4 ethernet connection just "no network access", so i tried linux, same issue, i tried a fresh install of W7... Same problem..
So now i bought a PCI-E X1 Broadcom NetXtreme Gigabit Ethernet NIC, and i am faced with the same issue on all OS and fresh install..
I tried the connection with a laptop using the same patch cables and devices to connect to, i can get the network working just fine but Internet connection sharing is not working for some reason, not that it matters because i don't plan on using the laptop.
My assumption would be that some kind of network interfacing chip on the motherboard is defective and prevents even PCI-E NIC's from creating a connection. Unless for some crazy reason only a crossover cable will work with both my onboard ethernet and PCI-E NIC, don't really understand what the difference would be but i would have to say the motherboard has defective network components.. Any help is appreciated, cheers.
