UniFi AP-AC-LR Issue
Don
23 Oct 2005
North Yorkshire
Hi all,
I've got 2 LR APs in my house, I decided to move one and seemingly have broken it!
At first, after moving it, it showed disconnected on the controller constantly despite being physically connected fine, POE on. I reset the device and adopted it again, still the same. After more messing about and moving it back, it still wasn't working. I then plugged it straight into the router, rather then the switch, it was connected, however at 100 FDX. I'm not sure why it was limited so messed around more, eventually moving it back to where I wanted it, it's using the other AP for it's up link rather than the cat5.
Any ideas?!
From what you are describing it sounds like a damaged cable/loose RJ45 connector. They're quite difficult to damage.
Any chance you can dig out the supplied injector for testing purposes? Remember Ubiquiti have changed PoE spec over the years, so double check if you have a few in the spares box.
