Hey all,
If anyone has experience with custom routing with the Ubiquity gateways, I need your help!
My current internal setup is:
What I'm wanting to achieve is communication from any device on my home network, on VLAN20, to VMs on my remote server. The way I was going to do it is:
- Spin another PfSense Gateway up on the home ESXi server, and assign two vNICs both on VLAN20 (for WAN and LAN)
- Spin another PfSense Gateway up on the remote server, and attach a LAN vNIC from each of the separate networks to this new gateway.
- Create a Site-To-Site VPN between these new gateways allowing communication
- (The part I'm stuck at) Somehow configure the local physical gateway at the home (the USG), to route any traffic going to 10.101.x.x from the local VLAN20 only (10.0.0.x), over to my new PfSense gateway which will sit on LAN 10.0.0.254 for example?
I hope that makes sense!
