Uniformity/uneven backlight
23 Apr 2020
Hello,
do you think this is normal/acceptable uniformity?
https://imgur.com/a/oVN3kTc
(probably the camera makes it look little worse)
This is my third LG 5K UltraFine exchange unit, 27MD5KL-B; each of the units had the same issue — uneven white where certain areas are slightly darker (most notably in the right side of the screen). The problem is visible only on white backgrounds.
My previous monitor didn’t had this issue. I’m not sure if I should just accept this as normal. Or all these are actually defective units part of bad batch?
Thanks,
V.
