Hi all
Had some free software come with a new PC,...CyberLink BD Solution v6, I had a little trouble installing this, but it went OK after a while,....
I don't like this software at all, so I want it gone..You know "Remove it"
It has no uninstall from inside the program itself, and when I try uninstalling from add/remove programs, the uninstaller keeps looping, like every second I get another uninstaller appear, then another, then another...So on and so on....Untill I have 500 uninstallers going on
The only way to stop this is a system reboot....How do I remove this Cr**P from my PC...
Any help with this will be gratefully received
Oops...Windows 7 Pro 64bit
Many thanks....
Swifty
Many thanks....
Swifty
Took a bit of time to get the hang of it, well, it does what it says on the tin
Found something I like better
