I have uninstalled BlueStack using the Windows 8.1 unstaller but having issues with removing the Bluestack notifiction install.
When going through the removal process, you are prompted "Do you want to keep your apps and data". If you say no, the process cancels and I cannot remove it.
I've been looking for an application to remove this installation without using the uninstallation shell for the software but I've found nothing.
I've also tried deleting the folder, but it says there are system files in the folder.
Recommendations?
Recommendations?
