Uninstalling an OSX update - Sound issue
20 Nov 2004
Nock/Leicester
Guys
I have a major problem and need your help.
I have installed the latest osx update and now have a problem. I have my Imac connected to an amp which is connected to my ceiling speakers. Before the update i could set the amp to 7.1 and would get sound via all speakers. Could also set to Hall, Arena, 2.1 etc.
But now i can't change this at all, the AMP just says NOT AVAILABLE. I can't set it to 7.1 and am currently only getting sound via 2 speakers!!!
How do i uninstall this silly update?! I do not have time machine set up sadly.
Check the "Audio Midi Setup" utility isn't now using a different source. Otherwise you're going to have to clean install.
How do i check the Audio Midi Setup?
Every time i do an update the output gets screwed!
Look in your Utilities folder and open it. Either from finder in the Applications folder or from Launchpad.
Backup AppleHDA.kext from /System/Library/Extensions, and replace it with the one I uploaded. Do a proper full reboot and fingers crossed it will be sorted. I had terrible crackling through my USB sound card post 10.7.2 and with the old kext, it works fine.
