Uninstalling and re-installing Corsair iCue
19 Oct 2002
Pembrokeshire
My Corsair iCue software fails to load properly and it's not allowing me to unistall it, the add/remove option in windows has the uninstall greyed out.
I downloaded the resource tool that corsair recommends but that did not list the software.
Any ideas?
Any ideas?
I had this problem.
You need to boot into safe mode then find and manually remove the Corsair folder (in program files iirc).
Reboot into normal mode and reinstall ICue from scratch. Don’t forget to export your profiles first if you have any.
I had this problem.
Thanks, I’ll try that when I get home
