Uninstalling programme leaves data files?
2 Jul 2021
United Kingdom
Hi, I've noticed that after uninstalling some programmes there are folders / files specific to the programme left over in the ProgramData folder, AppData Local & Roaming folder. I deleted them, is that ok to do ? I was very careful to delete just the files / folders relating to it.
Pretty standard from MS. Uninstalling rarely deletes everything, usually just what's in Program Files and maybe the other odd folder if you're lucky. The Windows registry is usually left full of crap afterwards too.
[Edit] I didn't realise a misspelled fish was a swear word ...
Pretty standard from MS. Uninstalling rarely deletes everything, usually just what's in Program Files and maybe the other odd folder if you're lucky. The Windows registry is usually left full of **** afterwards too.
Thank you!
