Unit conversion confusion
Permabanned
21 Apr 2004
Southampton University
Part of my coursework (different subject) involves following an example of calculations for test piece A and so doing the same for B,C and D.
At the end stage there is a unit conversion that has me confused.
18.28379004 N.mm^-3/2
to
0.5782 MN.m^-3/2
...I don't get that. I'm guessing it's the ^-3/2 that's the cause of the number changing rather than just the position of the decimal as it were, but I can't figure out for the life me how.
Not strictly, it's Newton Millimetres to the power of negative three over two and Mega Newton Metres to the power of negative three over two.
I have just found buried in an appendix that to convert I need to multiply by 10^-3/2 so now I can do it, though i'd still like a mathematical explanation of why i'm doing that so I understand it better, if anyone knows and can be bothered.
No, you need to divide by that number, mm to m is divide by 1000, so in your case it is divide by 1000^-3/2. (then divide by 10^6 to get it into mega Newtons).
1000^-(3/2) = 3.16^-5
1/(3.16^-5) = 31622 (spooky number, gives the same mantissa when inversed!!)
18.28379004 x 31622 = 578184.2 (/ 10^6)
= 0.5782 MN.m^-3/2
EDIT: OK your way of multiplying is fine, just be wary it converts straight to MN.m^-3/2 !)
