Unity C# problem
28 Jul 2014
Liverpool
I am currently coding my 2D game for Android and ran into a parsing error along the way. I am coding in C# and I can not seem to get shut of this error, I have tried closing and opening the brackets and still nothing. Any help would be appreciated. Thanks.
Line (30/1) error CS8025: Parsing error
rigidbody2D.velocity = Vector2.zero;
rigidbody2D.AddForce(jumpForce);
Code:
using UnityEngine;
using System.Collections;
public class Player : MonoBehaviour {
private Vector2 fp; // first finger position
private Vector2 lp; // last finger position
void Update () {
foreach(Touch touch in Input.touches)
if (touch.phase == TouchPhase.Began)
fp = touch.position;
lp = touch.position;
if (touch.phase == TouchPhase.Moved )
if(touch.phase == TouchPhase.Ended)
Vector3 newPosition = transform.position;
if((fp.x - lp.x) > 2) // left swipe
newPosition.x -=2;
transform.position = newPosition;
else if((fp.x - lp.x) < -2) // right swipe
newPosition.x +=2;
// Die by being off screen
Vector2 screenPosition = Camera.main.WorldToScreenPoint(transform.position);
if (screenPosition.y > Screen.height || screenPosition.y < 0)
Die();
// Die by collision
void OnCollisionEnter2D(Collision2D other)
Die();
public void Die() {
Application.LoadLevel("gameover");
6 Mar 2008
Stoke area
I don't code in c# and only have limited experience in other languages, but I count 12 { and 14 }
Having posted the code into sublime and just browsed through, it appears that the { on line 50 isn't paired:
Die();
and the very last } isn't paired either.
28 Oct 2006
Sufferlandria
As AHarvey says, lots of the braces are not paired either.
This is what the code looks like indented properly:
Code:
using UnityEngine;
	void Update ()
					newPosition.x -=2;
					newPosition.x +=2;
	Die();
// Die by collision
	Die();
public void Die()
Everything after the line which gives you the error seems to be in the wrong place. It should probably be inside the player class.
14 Oct 2008
England, Worthing
It can't parse the object, you need to instantiate the instance variable 'jumpForce'.
Your miss-use of brackets will also generate a compile/runtime error.
Code:
private Vector2 jumpForce = new Vector2(0, 300);
//change 0,300 to desired value(s).
   Class x
   { //Within the class
Man of Honour
13 Oct 2006
I like 4, or a tab ;)
Wasn't aware there was even a debate on it heh.
It should always be 1 tab unless your coding in 1-2 languages where that formatting causes issues. Anything else is either not clear enough or takes up too much screen estate.
