Hey everyone, quick question. I've just started building my first gaming pc. I've gone for the kolink unity peak and just like to know why the peak has normal fans pre installed and the arena has reverse blade fans pre installed. Only went for the peak due to the fact the umbra void pro fans imo, look much better than the umbra x that are pre installed in the arena case. So I'm Wondering if kolink changed them for aesthetic purposes or if the peak was maybe producing more or less positive/negative air pressure. Also the arena comes with a vertical gpu mount and peak doesn't so if anyone can also tell me which mount I could get to fit my peak case. I have gone an got hold of 3 gamemax kf300r and fitted 2 of them to the psu shroud and one on top of the hdd bay also I've fitted a umbra void 360 aio in top of case exhausting through the rad. So for the build I've gone with a msi a750gf psu, asus prime b760 plus d4 mobo, i5-14600k cpu, Rtx 4060 ti 3x 8gb, A crucial t500 2tb gen 4 nvme and gunna be using 1tb hdd pulled out of current pc. Any help or advice would be much appreciated
