Unknown Device In Device Manager
4 Sep 2005
UK
Just did a clean install of Vista Business 64 bit, on my Asus P5Q Deluxe motherboard, after install with ALL the drivers I know off installed, I am let with "Other devices -> Unknown device" with a yellow exclaimation in Device Manager, haven't been able for sure to track down what it belongs to, but on running Vista Update it gives me the option to download a driver called "ATK system - ATK0110 - ACPI Utility", which may have something to do with AI Booster...
Does anyone know what hardware this refers to, and does a driver need to be installed for it, or can I simply Disable it, or do you have any other suggestions regarding it?
Latest chipset drivers ? ACPI normally refers to deep-down driver......perhaps the one on the support CD was not 'happy' with 64-bit Vista ?
I had this last week after a reinstall and it was doing my head in until i remembered what it was. It's the EPU engine chip that saves power. You need to install AI Suite along with the software for it.
Hi, there is no need to install A1 at all, just leave the motherboard disc inplace and let Vista search for the driver. That's what I always do...
Chris
Chris
I am on XP though so had to install AI suite. Could'nt remember how Vista did things so did'nt go any further. At least i was right in what the problem was. :)
