unknown device!
7 Feb 2007
AM2 4200+
ASUS M2N SLI Deluxe
Fresh install of Win XP SP2
Device manager list reads:
Other devices - Base System Device
When I click on properties, list reads:
Device type: Other devices
Manufacturer: Unknown
"The drivers for this device are not installed. (Code 28)"
Does anyone know what this device is and what the appropriate driver is? I have installed drivers for all known devices on my desktop but cannot figure out what this one is.
Thank you for any help you might give!
I don't have that board, but the two recent Asus boards have sometimes not found "ACPI" Try updating the driver to ACPI driver file, it won't force install, just point it to the .inf/dll files and if it installs then that's it.
I can tell you now its the 'ATK0110 ACPI Utility'
you can install it by downloading the Ai Booster program, and just pointing it to that to find the drivers. or if you want the program too, just install it and it will do the rest..
Thanks buddy I'm gonna remote into my PC now with the good old magic packet to wake my pc up as I'm at work... if this works I'll have a crate of Stella delivered to your house :)
