Unknown Network Problem - "Invalid value for registry"
9 Oct 2011
Hi. I have a weird problem that none of my network connections are showing up:
I've tried various things: running the windows troubleshooter which resets the network, uninstalling the adapter, updating windows, running a registry cleaner (CCleaner), resetting windows firewall settings, disabling antivirus software, uninstalling VPN.
Its a wired connection straight from my router to my computer (Intel 82579V network adapter) running on Windows 10 (version 1909). Weirdly it still connects to the internet fine, but the settings are obviously completely messed up.
Thanks for your help!
Thanks for the suggestion. I hadnt done a sfc scan but have now - it found some corrupt files and fixed them but unfortunately the problem still remains. The rest of my computer is working fine
Thanks for the suggestion. In the end though I did a repair install of Windows. Bit of a brute force method, but Im pleased to say it worked :)
