Unlock GPU Voltage in TriXX ?
20 May 2007
Never used TriXX but thought id give it a whirl and MSIAB is being a right PITA for me on these 7970s
There doesn't seem to be an option to unlock the voltage adjustment - Can TriXX do this ?
An I being dense or is there some whizzy magic I need to perform to get it to work ?
Ta :)
Make sure you scroll down in the overclocking tab, it's called vddc :)
Though only afterburner works with the lightnings...
Yeah, I saw that (eventually :P) but it doesnt seem to be unlocked to get the voltages MSIAB can :(
Cheers mate :)
@ pgi
It just randonmly "locks up" or becomes tediously slow
If I then try and move it round the screen it randomly ghosts like mad and then locks up
@ Martin
May well do mate ;)
MSI AB for some reason does not work as well as TRIXX, TRIXX just seems to hold the volts i set that bit better.
Nothing other than ab at the moment will give you voltage control on a lightning.
Have you tried the ln2 bios?
Give it a whirl, its fully unlocked from the off so if any of the issues are related to AB unlocking this could be why.
I did have an issue getting anything to unlock on AB while using 12.11 beta4, but I'm under the impression that was down to my windows install being completely full of junk :p
