How does the shader unlock + overclock differ from "full" unlock.Don't unlock them to 6970's, just get the shaders mod and then overclock with MSIAB. Lots of cards dieing after 2 weeks with the full unlock, the memory timings iirc.
750w+ psu I would imagine for a crossfire setup.
Where have you seen info on lots of cards dieing after 2 weeks ?
Even if the timings were different (which of course they will be, as they use slower RAM), that would only result in crashing and instability, not card death.
Muchlike tightening your RAM timings beyond that which they are designed for at a given speed. You don't kill your RAM, you just end up with an unbootable/unstable system.
Are the 6950 and 6970 PCB's and components identical? I don't think they are so quite likely that trying to run a 6950 with a 6970 BIOS would cause problems. Just unlocking the shaders however would be less stressful I imagine...
