I'm having difficulty with my cards as per this thread: (sorry to link like this but its not too bad at three pages and has all the info there)
http://forums.overclockers.co.uk/showthread.php?t=18543311
I think there must be something we are overlooking and thought you might welcome the change from the usual CPU ocing questions.
I am on air currently so not sure what my max safe volts should be, I am measuring with a multimeter so know the true values.
I would feel more comfortable back underwater but can't justify the blocks right now.
What I don't get is that the memory won't even do +250mhz
I'd appreciate your tips
PS: oh and is my 2500k ok at 1.5v 5ghz? 1.48v underload in CPU-Z. Passed 10 iterations of prime which is good enough for me but I note your current thinking is daily use is what matters and that errors will not build up this way. I've always felt this too but there's the dogma ingrained to use prime. I might ease the volts and see if its games stable after I get these cards sorted
