Ok im after a budged Quad core rig for my father for use with solidworks.
I will be buying this motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-373-AS
Should i buy the Phenom 965 quad or go with a x2 550?
Can the above motherboard unlock the 2 cores? Is it a difficult task? What are the chances i will not be able to unlock the cores?
