Unlocking phone question
3 Sep 2007
Is there any free reliable software out there that will generate the unlocking code for any mobile phone so it can be used on different networks?
thanks in advance
it depends on what phone you've got. theres the bb5 unlocker which does a lot of phones apart from the n series of nokias, think it does a few other brands as well. safest way is to get the network to do it or down a local market shop so you dont block it by putting in 3 wrong codes.....or is it 5 i forget :confused:
Theres a lot of speculation about the BB5 unlocker, iv read up it definately cannot unlock the N series as they can only be unlocked from the original provider its locked to apparently. Been looking for one for when my 6300 comes through so i can get that unlocked.
Liam
