unlocking x3 450
27 Sep 2011
I'm trying to unlock my X3 450, it all looks good up to the BIOS enter screen but after that the screen just stays black. I can enter the BIOS and it displays as a X4 B50. Is there anything else I can try? I've tried to up my vcore slightly but i'm not convinced i'm doing it right because CPU-Z doesn't recognize the change. :confused:
Also ACC shows 6 cores so do I have a hex core with 3 cores turned off? I must be pretty unlucky if they are all faulty?
tri cores cannot unlock to 6 cores, only the phenom X4's can and only some of them can.
I would check the net and see which processors can be unlocked. I know it is only the Phenoms which can and the one or two athlons.
Also, which motherboard are you using? This is a big factor!
