unofficial annoucement of 45nm intel desktop cpu's:)
28 Jan 2007
Manchester
http://www.digitimes.com/mobos/a20070817PD207.html
Intel recently increased the number of 45nm-based CPUs it plans to launch for desktop PCs to nine, according to sources at motherboard makers.
Within the nine CPUs, five will be dual-core processors (Wolfdale) and the remaining four will be quad-core (Yorkfield). All will adopt a 1333MHz FSB. Model numbers for the upcoming products are still undecided, noted the sources.
Four of the five Wolfdale processors will have core frequencies of 3.16GHz, 3.0GHz, 2.83GHz and 2.66GHz, while the frequency of the remaining one is unknown. All five Wolfdale processors will feature 6MB L2 cache, detailed the sources.
Three of the four Yorkfield processors will have core frequencies of 2.83GHz, 2.66GHz and 2.5GHz with the remainder as yet unknown. Three will include 12MB L2 cache while the 2.5GHz version will have 6MB.
Intel will introduce the ability to increase the clock multiplier in steps of 0.5 in the upcoming 45nm range to increase its model choices, pointed out the sources.
With Intel aiming to eventually scale the 45nm range up to a maximum core frequency of 4.0GHz, the sources estimate that at least four more CPUs will appear at a later time with frequencies higher than the initial 3.16GHz.
Intel declined the opportunity to respond to this report, saying it cannot comment on unannounced products.
Yay, 0.5x multi, FINALLY!!!
